How to submit a job
This section explains how to submit a job without the parametric distribution.
Reach the submission page of your PBS installation and select Flux application.
You should see an interface as shown in the next figure:
Job Name
Enter the name of the job to be submitted.
Version
In the dropdown list, select the item corresponding to the version of Flux ™ that you want to use.
Flux application
In the dropdown list, select the Flux application of all inputs: Flux2D, Flux3D, FluxSkewed or FluxPEEC
Important: All the inputs must be of the same application.
Input file
Put the file containing the Flux project(s) to solve and/or python script(s) to execute. See section Input file for more details.
Parametric distribution
Enables the parametric distribution feature. Let it uncheck for this section.
Memory management
Check to enable the dynamic memory management.
Number of cores per job
Set the number of cores you want to use per job.
Memory (GB) per job
Set the amount of memory (in GB) you want to allocate per job.
Walltime
Set the maximum duration of the job. The job will be killed once this duration is exceeded.
Output Directory
Optionally you can set the output directory of your choice. The output directory will contain the results. By default, the system will automatically create and assign a stage directory.
Important: The given directory must be accessible by every node.
Submit
Click to submit the job. The job status can be found in the Monitoring page.
