Other available PyFlux commands
Introduction
There are additional commands available to the user that are not accessible by recopying a sequence of PyFlux.
Commands
The available commands are as follows:
  • startMacroTransaction() / endMacroTransaction()
  • getProjectName()
  • [ALL]
  • getHelp()
  • getPyFluxCommande()
These commands are described in the next sections.
startMacroTransaction()/endMacroTransaction()
The description and applications of this command are explained in the table below.
Commands startMacroTransaction() / endMacroTransaction()
Function Permits the regrouping of a set of commands in a block.
Use
# set of PyFlux commands
Example : Pyflux sequence
Creation of a triangle :
PointCoordinates(color=Color['White'],
                 visibility=Visibility['VISIBLE'],
                 coordSys=CoordSys['XYZ1'],
                 uvw=['0',
                 '0',
                 '0'],
                 nature=Nature['STANDARD'])
                 uvw=['0',
                 '0',
                 '10'],
                 uvw=['10',
                 '0',
                 '0'],
LineSegment(color=Color['White'],
                 defPoint=[Point[1],
                 Point[2]],
                 defPoint=[Point[2],
                 Point[3]],
                 defPoint=Point[[3],
                 Point[1]],
Example : note The commands are evaluated and the graphics refreshed at the end of the sequence, permitting the acceleration of the process.
getProject Name()
Commands getProjectName()
Function Permits the recovery of the name of the project open in Flux
Use Name= getProjectName() permits the storage of the project name in the ‘Name'variable
Example : PyFlux sequence
Display of the Flux project name in a file :
file = open("Name of project","a")
file.write("Name of project :")
file.write(getProjectName())
file.flush()
file.close()
[ALL]
Commands [ALL]
Function Creates a the list of all entities of the same type which facilitates the storage of this list in a ‘Flux variable'
Use Points = Point[ALL] creates a list of all entities of the point type and enables the storage of this list in the « Points » variables.
Reminder / Comparison
The command List_instance(typeId='Point')* results in the display of all entities of the point type displayed in the History zone.
* syntax equivalent to the command List described under § § 5.3.2 Informations sur les entités : Afficher l'expression Pyflux, Lister, et Utiliser par..
Display of a detailed list of entities belonging to the same entity type in a file:
file = open("List of entities", "a")
file.write("Detailed list of points")
for I in Point[ALL] :
   file.write("\n\nInstance : ")
   file.write(repr(I))
   for field in Point.__fields.keys() :
      file.write("\n")
      file.write(field)
      file.write(" : ")
      file.write(repr(I.__getattr__(field)))
file.flush()
file.close()
Example : result
Content of the created file:
Detailed list of points:
Instance : PointCoordinates[1]
visibility :'VISIBLE'
surface : None
color :'White'
domain :'DOMAIN1 : Domain.'
nature :'STANDARD : Topologie standard'
inAirPointFaceLocation : None
region : None
globalCoordinates : [-0.06, 0.0, -0.05]
ETAT : 0
mesh :'E_SHAPE : E_SHAPE VOLUMES'
inAirPointVolumeLocation : None
Instance : PointCoordinates[2]
surface : None
color :'White'
region : None
globalCoordinates : [-0.04, 0.02, -0.05]
ETAT : 0
getHelp()
Commands getHelp()
Function
Permits to stor the help text dealing with an entity type in a
« Flux variable ».
Use Point = Point.getHelp() retrieves the syntax describing the « Point » entity type in order to support storage in the « Point » variable.
Reminder / Comparison The command Point.help() permits the display of the support storage of the Point entity in the history zone.
Display of support related to an entity type in a file:
file = open("Aid PyFlux","a")
file.write("Aid on the point :")
file.write(Point. getHelp())
file.flush()
file.close()
Example : result File created comprising all of the supporting Pyflux command syntax associated with the « Point. » entity type.
getPyFlux Command()
Command getPyFluxCommand()
Function Permits the storage of ann entity in a « Flux variable ».
Use P1=Point[1]. getPyFluxCommand() permits the storage of the Point[1] entity in the « P1 » variable
Reminder / Comparison The command Point[1]. type() permits the display of the entity Point[1] in the history zone
Display of an entity in a file:
file = open("Entities of the Flux project ","a")
file.write("Point P1 :")
file.write(Point[1]. getPyFluxCommand())
file.flush()
file.close()
Example : result
Content of created file:
Point P1:PointCoordinates(color=Color['White'],
                        coordSys=CoordSys['CENTER'],
                        uvw=['-60',
                        '0',
                        '0'],
                        nature=Nature['STANDARD'],
                        mesh=MeshPoint['E_SHAPE'])
