The
derived data collections enable to define data collections
                by applying an operation on one (or several) existing collections. These derived
                collections are divided in three types:
                    - Fourier transformations, obtained applying an FFT
                        algorithm to the values of a collection. Only the collections defined on a
                        time interval are compatible. The created collection inherits of the
                        transformed collection support. The user:
                            - should specify the specific step interval,
                            - can tick or not the option "Automatic duplication of forces for
                                    rotating machines". If activated, this option reconstructs the FFT on all the
                                periodicities of the device (e.g. the full device), allowing the user to reduce the number of
                                scenario time steps to solve. In order that this duplication can be performed, the solved scenario
                                must cover at least one electrical period of the device and the selected step interval must be a whole
                                submultiple of the mechanical period, so as that the force values at the first and the last interval step
                                are identical. Moreover, the device has not to be studied during its
                                acceleration phases (ex. no coupled load), since the speed of the
                                rotating mechanical set must be constant.
                    - Simple operators, enabling to extract the different values,
                            Maximum,
                            Minimum,Average
                            (statistics), Sum or RMS
                            Values of a multi-steps collection. Single step collections
                        are not compatible. The created collection inherits of the transformed
                        collection support. The user should specify:
                            - a specific step interval,
                            - the operator to apply.
                    - Harmonic excitations, which allows to define a collection similar to the
                        collections obtained by Fourier transform, but by defining directly
                        different components values (continuous and harmonic) through the
                        combination of other collections values. The chosen collections to compose
                        this type of collection must share the same support and a same data type
                        (nodal or elementary, scalar or vectorial). The created collection inherits
                        of the transformed collections support. The user should specify:
                            - a collection defining the continuous component. This collection
                                values should be reals,
                            - a collection defining the harmonic component. This collection values
                                should be complexes,
                            - a frequency associated to the harmonic.
