Manipulation of the electric circuit components in the standard context
Selection mode
The selection modes are presented in the table below.
A component of a circuit… Is selectable …
imported
  • in the Data tree
  • in the graphic zone tab CircuitView (if the format contains a graphic description (*.ccs and *.xcir))
Select and Edit a component starting from the data tree
To select and then edit a component of the electric circuit starting from the Data tree:
Step Action
1
Select the component in the Data tree:
  • point and click on the desired component
The component is highlighted
2
Edit the component in the Data tree:
  • double click on the selected component
or
  • click right on the selected component and choose Edit or Edit in a table
The dialogue box corresponding to the component is opened
The user can characterize or modify the circuit component
Select and edit a component in the graphic zone CircuitView
To select a component of the electric circuit starting from the graphic zone available on the CircuitView tab:
Step Action
1
Select a component of the circuit:
  • in the tools bar Selection, activate the icon of selection of the desired component
  • in the graphic zone CircuitView tab:
  • click once on the desired component
2
Edit the circuit component:
  • double-click on the desired component
or
  • click right on top and choose Edit or Edit array
The dialogue box corresponding the component is opened
Modifying/ characterizing an electric circuit component
To modify or characterize a component of the electric circuit under the editor (name, comment, model, terminals*):
Step Action
1 Select the desired component
2 Edit the component or Edit array
3
Modify the information in the dialogue box:
  • choose the desired tab (tabs only available for the entities of component types)
  • enter the desired information in the corresponding zones.
4
Validate the information:
  • click on OK
The component is characterized/modified
Delete a component in the Data tree
To delete a component starting from the Data tree:
Step Action
1 Select the component to delete
2
Activate the command:
  • open the contextual menu by the right button of the mouse
  • click on Delete / Force delete
A confirmation box is opened
3
Confirm the deletion:
  • click on OK
The component is deleted
Note: it is possible to delete several components at the same time only if they are of the same type
