Cut plane
Creation of cut planes
To create a cut plane:
Step Action
1
Open the dialog box:
  • click on the icon or
  • in the Tools menu, click on New
The dialog box New cut plane is opened.
2
Create a cut plane:
  • give a name to the cut plane
  • possibly insert a comment for this cut plane
3
The cut plane can be defined by:
  • a face; select the desired face
  • a top and an edge; select the desired top and edge
  • three tops; select the three desired tops
  • a XY plane; specify the Z coordinate of the cut plane
  • a XZ plane; specify the Y coordinate of the cut plane
  • a YZ plane; specify the X coordinate of the cut plane
  • an equation Ax+By+Cz+D=0
4
Confirm by clicking on OK
The cut plane appears on the screen.
