Coordinate system: by default
Default coordinate system
To facilitate the work of the user, Flux PEEC provides a working coordinate system. It is created for every new project. It is possible to rename, to modify or to delete it.
Predefined coordinate system
The default working coordinate systems proposed to the user are:
  • of cartesian type
  • defined with respect to the global coordinate system using:
    • for length unit the millimeter
    • for angle unit the degree
3D domain
Coordinate system Characteristics
XYZ1
Origin of coordinate system:
  • first component: 0
  • second component: 0
  • third component: 0
Rotation angle:
  • about X axis: 0
  • about Y axis: 0
  • about Z axis: 0
