Entity selection: Circumstances and selection modes
Introduction
The most part of actions for handling the entities require the selection of entities .
Indeed:
  • to modify the coordinates of a point, you should select the corresponding point
  • to add a line (segment), you should define extremity points and then select starting point and ending point
The different selection circumstances and selection modes are presented in this paragraph.
Selection circumstances: overview
Selection of entities could be done before or after the activation of a command; it could also be done, during an operation of creation.
These various circumstances of selection are presented through examples in the table below.
Selection before activation of a command
… Activation of a command:
  • Edit
  • Edit array
  • Delete
  • Force delete
Selection after activation of a command (via selection box)
  • Edit
  • Edit array
  • Delete
  • Force delete
Selection during an operation of creation
  • New
Selection modes: overview
Selection of entities could be done with the following different selection modes:
  • graphic selection (directly with the mouse)
  • in the data tree for all entities
  • in the graphic area for graphic entities
  • identifier selection (by name / by number )
  • criterion selection* (by relation / by … identical characteristics )
* the advanced selection is detailed in § Entity selection: Selection by criterion
Summary
The different selection modes proposed function of selection circumstances are gathered in the table below.
Selection circumstances Selection modes
Selection before
  graphic
Selection after
Selection box
graphic
by identifier (name/number)
by criterion
Selection during
Specialized box
graphic
