Preferences: Snapping
Define preferences for snaps.
Snapping
| Option | Description | Note |
| Snap to Visible | Only snap to visible geometry. | This helps prevent snapping to objects that are behind other objects. |
| Grid | Snap to the closest point on the grid when sketching or translating. | Grid spacing can be changed in the Preferences window under Drawing. |
| End | Snap to end points. | |
| Middle | Snap to midpoints. | |
| Center | Snap to center points. | |
| Center Arc | Snap to center arc points. | |
| Intersection | Snap to intersection points. | |
| Quadrant | Snap to quad points. | |
| On | Snap to any point on a sketch curve with the mouse cursor. | Only available in sketching mode. |
