LS-DYNA Interface 2022 Release Notes
LS-DYNA Interface
New Features
New Integration Rules entity
LS-DYNA keywords *INTEGRATION_SHELL and *INTEGRATION_BEAM, previously supported in Property entity, are now mapped to their own entity.
New Perturbation entity
LS-DYNA keywords *DEFINE_STOCHASTIC_VARATION and *DEFINE_STOCHASTIC_VARATION_PROPERTIES, previously supported in Property entity, are now mapped to their own entity.
New Frequency entity
LS-DYNA keywords *FEQUENCY_DOMAIN_(OPTIONS) are now supported and mapped to the new Frequency entity.
Enhancements
New Keywords
  • *CONSTRAINED_LINEAR_GLOBAL
  • *CONSTRAINED_LINEAR_LOCAL
  • *DEFINE_FUNCTION_TABULATED
  • *EOS_JWLB
  • *EOS_MIE_GRUNEISEN
  • *EOS_GASKET
  • *EOS_MURNAGHAN
  • *EOS_PHASE_CHANGE
  • *MAT_MODIFIED_JOHNSON_COOK (*MAT_107)
  • *MAT_DAMAGE_3 (*MAT_153)
  • *MAT_MUSCLE (*MAT_156)
  • *MAT_MOHR_COULOMB (*MAT_173)
  • *MAT_NON_QUADRATIC_FAILURE (*MAT_258)
  • *PART_AVERAGE
  • *SENSOR_DEFINE_FUNCTION
  • *SET_NODE_LIST_SMOOTH
Updated Keywords
  • Update in *CONSTRAINED_INTERPOLATION to support independent nodes with a *SET_NODE when ITYP=1
  • LS-DYNA R11.1: New ELFORM value in *SECTION_SOLID
  • LS-DYNA R12.0: Updates in *EOS_GRUNEISEN and *EOS_TABULATED_COMPACTION
Solver Mass entity management
A new option in the Appearance Preferences allows you to display the graphics on nodal masses defined inside the *ELEMENT_MASS Solvermass entity.
With the graphics activated, you are now able to manage the individual nodal masses. For example:
  • Organize a selection of nodal masses into another Solvermass entity of type *ELEMENT_MASS.
  • Select and edit any nodal mass and modify the mass value.
  • Select and delete any nodal masses defined into a Solvermass entity of type *ELEMENT_MASS.
Resolved Issues
  • Export Solver Deck feature, when selecting a material linked to multiple MAT_ADD cards: all linked MAT_ADD keywords are now exported with the selected material.
  • Removed Title checkbox in *DEFINE_FUNCTION keyword Entity Editor.
