2022
Run the model and view results.
View new features for HyperLife 2022.
Discover HyperLife functionality with interactive tutorials.
Fatigue Analysis is intended for solutions to structures in a large number of loading cycles.
Set up your model for analysis.
Use the Run Analysis tool to set up and launch the evaluation.
Use the Batch tool to run submission in batch.
A log file outputs the HyperLife evaluation summary for a particular run.
Use the Results Explorer to view plots and contours for various result types.
View a list of runs saved in your home directory or the current active session.
Entity type selection for Fatigue Evaluation.
Explore additional post-processing options related to the input result files.
View All Altair Simulation Help
ON THIS PAGE
