HL-T: 1110 Sine Sweep Fatigue Analysis – Stress-Life
- Import a model to HyperLife
- Check that the FE result file contains a frequency response function (FRF) subcase with element stresses
- Select the SN module with a Sine Sweep loading type and define its required parameters
- Create and assign a material
- Create a sine sweep event
- Evaluate and view results
- HL-1110\bracket_SineSweep.h3d
