2022
Learn how to manipulate entities in HyperLife Weld Certification.
Learn how to work with entities using the Entity Editor.
View new features for HyperLife Weld Certification 2022.
Discover HyperLife Weld Certification functionality with interactive tutorials.
Set up the model for weld evaluation.
Learn details about the core modules used in HL-WC calculations along with the parameters that are assigned based on the standards.
Learn the basics of working with entities.
Every entity is assigned solver specific data, which you can modify using the Entity Editor.
Create, edit, and assign new entities to an existing entity or group of entities in the Entity Editor.
Certain entities can be defined with parameters in the Entity Editor.
Filter the entities that are not applicable to the entity displayed in the Entity Editor.
Display a warning dialog when changing information in the Entity Editor.
Set entities are used to define and store lists of entity IDs for a specific entity.
View All Altair Simulation Help
ON THIS PAGE
