Select and deselect entities to modify with other HyperLife Weld Certification tools. Selected entities are outlined to indicate their selection state.
Input Requirements
Discover the files required to work with HyperLife Weld Certification.
User Interface
Explore the HyperLife Weld Certification user interface.
Adjust the View View controls enable you to control the view and display of your model in the modeling window.
Graphical Selection
Move and Snap
Translate, rotate, and align the model.
