OptiStruct Utility Menu
The Utility menu for the OptiStruct user profile contains, in addition to the default Utility menus, three pages (Summary, FEA and Opti) of specific utilities for OptiStruct.
View new features for HyperMesh 2022.
Discover HyperMesh functionality with interactive tutorials.
Browsers supply a great deal of view-related functionality in HyperMesh by listing the parts of a model in a tabular and/or tree-based format, and providing controls inside the table that allow you to alter the display of model parts.
Learn the basics of working with browsers.
Use the Assembly Browser to manage parts and modules during the assembly building process.
Use the Connector Browser to view and modify connectors in the current model.
Use the Contact Browser to create, review and modify contact interfaces and surfaces in a model.
The Entity Editor enables you to quickly view and edit entities in a model and correctly setup solver information.
Use the Entity State Browser to set various states for entities in a model.
Use the Loadsteps Browser to create, manage and display loadsteps (sub-cases) and the associated control cards.
In the Mask Browser, set the mask/unmask state for entities at the entity configuration level.
Use the Mass Trimming tool to create, define and realize mass entities.
Use the Matrix Browser to explore the HyperMesh and HyperView data entities and export the entities to external files for further analysis.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Use the Model Browser to view the model structure while providing full find, display and editing control of entities.
Check the solver validity of the model, identify modeling issues, and fix modeling issues in an automatic or manual way.
Use the Part Browser to create, organize and manage the CAE part structure/hierarchy.
The Reference Browser enables you to quickly understand complex relationships between different entities that constitute the model.
The Solver Browser provides a solver centric view of the model structure in a flat, listed tree structure.
Create, organize and manage the CAE subsystem level models using any entities.
The Utility menu contains options that allow you to customize the standard interface to include function buttons, radio options, and text that have HyperMesh-supplied and user-defined macros associated with them.
The QA Utility menu contains many tools to help you quickly review and clean up the quality of a pre-existing mesh.
In the Disp Utility menu, clear temporary nodes if needed.
This menu contains a set of macros related to working with model geometry, as well as a set for working with FE mesh.
Macros are included on the Abaqus page of the Utility menu when you load the Abaqus user profile.
The macros on the ANSYS Utility menu simplify some common tasks for the ANSYS user profile.
The LS-DYNA Utility menu contains shortcuts and tools that can help simplify LS-DYNA tasks. Set the user profile from the User Profiles option of the Preferences menu.
The MADYMO utility contains utilities, tools, macros and shortcuts to display options.
The Nastran user profile contains two macro menus on the Utility menu: Nastran1 and Nastran.
The PAM-CRASH 2G Utility menu (pamcrash2G.mac) contains shortcuts and tools that help simplify PAM-CRASH 2G tasks.
The macros on the Permas Utility menu simplifies some common tasks for the Permas user profile.
The Summary page of the OptiStruct Utility menu lists a short summary using displayed or the entire model for components, loads, elements, center of gravity, moment of inertia, responses and constraints.
Macros available on the FEA page of the OptiStruct Utility menu.
Macros available on the Opti page of the OptiStruct Utility menu.
Use the Visualization controls to change many of the visual states in HyperMesh and HyperView.
ON THIS PAGE
The Summary page provides a short summary of the entities making up the model. The FEA page is dedicated to modeling and load setup, while the OPTI page is devoted to optimization. The Utility menu is available on the Utility tab when the OptiStruct user profile is loaded. The Utility tab may be activated/deactivated from the View menu.
ON THIS PAGE
