Optimization Methods
Numerical methods available for an Optimization approach.
Constraint violation tolerance and constraint threshold are set in the Objectives/Constraints - Goals tab of the Define Output Responses step within the Definition. For more information, visit Constraints.
Method Input Variable Model Restrictions Input Variable Constraint Restrictions Distribution Role # of Objectives Exploration Type Accuracy Efficiency Comments
Adaptive Response Surface Method (ARSM) None None Deterministic Single Local ✩ ✩✩✩ Default method for single objective problems.
ARSM-Based Sequential Optimization and Reliability Assessment (SORA_ARSM) Continuous only Input variable constraints are not allowed Probabilistic Single Local ✩ ✩✩✩ More efficient than Sequential Optimization and Reliability Assessment, but not as accurate.
It is not recommended to use ARSM-Based Sequential Optimization and Reliability Assessment with a Fit.
Genetic Algorithm (GA) None None Deterministic Single Global ✩✩ ✩ Significantly expensive.
Use Genetic Algorithm if the simulation is affordable or if you have a good Fit.
Global Response Search Method (GRSM) None None Deterministic Single or Multiple Global ✩✩✩ ✩✩ Default method for multi objective problems.
Preferred method when the number of design variables is large.
Optimizing can start with just a few number of points independent of the number of design variables.
Method of Feasible Directions (MFD) Continuous only Input variable constraints are not allowed Deterministic Single Local ✩✩ ✩✩ May work more efficiently for problems with a large number of constraints.
Multi - Objective Genetic Algorithm (MOGA) None None Deterministic Multiple Global ✩✩ ✩ Significantly more expensive.
Use Multi - Objective Genetic Algorithm if the simulation is affordable or if you have a good Fit.
Sequential Optimization and Reliability Assessment (SORA) Continuous only Input variable constraints are not allowed Probabilistic Single Local ✩✩✩ ✩ Use if the simulation is affordable or if you have a good Fit.
Sequential Quadratic Programming (SQP) Continuous only Input variable constraints are not allowed Deterministic Single Local ✩✩✩ ✩✩ Use if the simulation is affordable or if you have a good Fit.
System Reliability Optimization (SRO) None None Probabilistic Single Global ✩✩✩ ✩✩ Default method for probabilistic problems.
In robust optimization, it provides the trade-off between the nominal value and variance of the objective.
Xopt (User-Defined Optimization Engine) None None Deterministic Single
