Gradient Post Processing
Visualize gradients using vectors.
Analyze Vector
Analyze the vector in a gradient plot from the Gradient tab. Representing gradients as a vector field is an effective way to see gradients in space.
  1. From the Post-Processing step, click the Gradient tab.
  2. Use the Inputs and Output tabs of the Channel selector to select three dimensions of data to plot.
  3. Analyze the direction and intensity of the vector created using the selected data sets.
Gradient Tab Settings
Settings to configure the plots displayed in the Gradient tab.
In the Gradient tab, use the Channel selector to select data to display in the gradient plot.
Channel Settings
X-Bounds: display the X bounds in the plot.
Y-Bounds: display the Y bounds in the plot.
Output
Gradient: display the vector in the plot.
