NVH Grid Participation Utility (HyperView only)
The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour capabilities in HyperView to isolate key contributing areas.
The files that are needed for post-processing are:
OptiStruct.h3d file
PFGRID.h3d - which contains the participation data output, as well as information regarding the fluid-structure grids and elements.
MSC Nastran .op2 file
PFGRID.op2 – which contains the participation data output, as well as information regarding the fluid-structure grids and elements.
OptiStruct punch file
PFGRID.pfmode.pch – which contains the participation data output.
PFGRID.interface - which contains information regarding the fluid-structure interface grids and elements.
Note: For detailed information on how to run a grid participation output from OptiStruct, see the OptiStruct online help.
