2022
Create and import/export sets, create user defined coordinate systems, or use the symmetry visualization tool.
Animation files are opened using the Load Model panel.
View new features for HyperView 2022.
Discover HyperView functionality with interactive tutorials.
Use the Load Model tool to load model and result files.
Use the Sets tool to create, import, and export sets/groups of components (parts), elements, and nodes.
Create your own user defined coordinate systems or select result coordinate systems.
Symmetry visualization allows partially modeled geometry to be shown in full extent by reflection and/or duplication or in the case of axisymmetric models, by 3D geometry generation.
Explore the various result plotting tools.
Annotate model results using the Measures, Notes, Tracing, Image Planes, and Build Plots tools.
From the Tools menu, you can access various panels and dialogs.
From the Preferences menu, you can define file export settings and access the Options dialog.
The Aerospace menu provides you with access to various aerospace tools.
The NVH menu provides you with access to various NVH utilities.
The Vehicle Safety Tools (VST) is a collection of over 200 macros, Templex functions, and external functions for use by a vehicle safety engineer.
A new workflow emphasizing upfront data loading for standard crash post processing use cases.
Supported solvers in HyperView.
HyperView help for HyperWorks.
View All Altair Simulation Help
