*airbagfoldingsequences()
Creates an airbagfoldingsequence in HMASCII format.
*airbagfoldingsequences (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the airbagfoldingsequence.
name
The name of the airbagfoldingsequence.
color
The color of the airbagfoldingsequence. Valid values are 1-64.
To create an airbagfoldingsequence with ID 100, name "my-entity", and color 1:
*airbagfoldingsequences(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.1
