*airbagfolds()
Creates an airbagfold in HMASCII format.
*airbagfolds (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the airbagfold.
name
The name of the airbagfold.
color
The color of the airbagfold. Valid values are 1-64.
To create an airbagfold with ID 100, name "my-entity", and color 1:
*airbagfolds(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.1
