*airbags()
Creates an airbag in HMASCII format.
*airbags (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the airbag.
name
The name of the airbag.
color
The color of the airbag. Valid values are 1-64.
To create an airbag with ID 100, name "my-entity", and color 1:
*airbags(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.1
