*behaviors()
Creates a behavior in HMASCII format.
*behaviors() (id,"name",color)
HyperMesh HMASCII Command
Additional attribute or dataname information is provided separately, see referenced commands.
id
The ID of the behavior.
name
The name of the behavior.
color
The color of the behavior. Valid values are 1-64.
To create a behavior with ID 100, name "my-entity", and color 1:
*behaviors(100,"my-entity",1)
Incorrect usage results in an import error.
Version History
2021.1
