HMIN_designvar_writemingap()
Writes the minimup gap parameter associated with the topology design variable.
void HMIN_designvar_writemingap(double mingap);
HyperMesh hminlib Function
Writes the minimum gap parameter associated with the topology design variable.
mingap
The minimum gap value. Applicable only for topology design variables that have a maximum diameter specified.
A design variable must exist (HMIN_designvar_write()).
None.
Version History
11.0
