Vehicle Libraries
The automotive solution in MotionView provides a comprehensive vehicle library of Cars, Trucks and Motorcycles that can be used to simulate suspension behavior and full vehicle dynamics.
- Car/Small Truck Library
- Heavy Truck MDL Library
- Two-Wheeler MDL Library
The vehicle library is intended to provide a good starting point in the design of vehicles. The models contain generic data. You are responsible for populating the model with the appropriate data, such as suspension geometry, spring and damper parameters, mass and CG location, bushing data, tire and road data, and other model information that is required to develop an accurate vehicle model.
