HyperStudy and MotionView
- Select HyperStudy from the Applications menu.Figure 1.
When you open HyperStudy from within MotionView, you have direct access to the MDL database to perform design parameterization.
- MotionSolve
- ADAMS
- Abaqus
All entities in the MDL model tree can be accessed for defining design variables. In addition, models can also be parameterized using a base input template derived from the ASCII solver input.
