Saving Model Files
                From the File menu select Save > Model.
Figure 1.Or
Click the Save Model button
 on the Standard toolbar.Note: If the model in the data base is a new model, a dialog will be displayed. However if the model already has a file name, it will be saved directly (no dialog will be displayed). -
                From the Save As Model dialog, specify a file name and
                    click Save.
Figure 2.The model is saved.
