USERWI Engine Interface Routines
- USERWINDOW_GET_A(A_BUF)
- Gets the node forces from previous explicit cycle.
- A_BUF
- A 3xNUMNOD array must be allocated before calling the routine.
- USERWINDOW_GET_AR(AR_BUF)
- Gets the nodal moments from previous explicit cycle.
- AR_BUF
Example Demo File
