User Triangular Shell Elements Using Solid Property Example
A triangular shell property is defined using a user solid property with rotational degrees of freedom at nodes.
Bricks are degenerated to three node shells. Property reads stresses computed in a user’s material. Internal forces, internal moments, and strain increments are written.
Figure 1. 3-node-shell Mesh Made Up of Two Degenerated Brick Elements
Figure 2. Element Degeneration
Example Demo File
