Warning Message Database
This section is comprised of warning messages in ascending numerical order.
#100 through #699
Warning 194
WARNING ID : 194
** WARNING IN HIERARCHY REFERENCE
DESCRIPTION :
-- SURFACE ID : 8300005857
-- INTER_group_830006186_of_PART_TITLE : PART
REFERENCE TO UNEXISTING ID=600000000
The Starter will print this message when an object (node, element, part, subset) is defined in a group of node, element, surface or line but does not exist in the model.
600000000
is defined in the surface
830005857
. This part does not exist in the model. The
objects that are referenced but not defined in the model will be shown in
HyperCrash in the Model Browser as “Unresolved IDs”.
Either remove the group or select object to redefine the group.
Warning 542
WARNING ID : 542
** WARNING RIGID BODY INERTIA
DESCRIPTION :
-- RIGID BODY ID : 136849917
-- RIGID BODY TITLE : MAT_RIGID_1500016_PART_325
UNPHYSICAL INERTIA :
PRINCIPAL INERTIA 249.2162969709 IS GREATER THAN THEN SUM
OF THE 2 OTHER ONES 112.70695453317 + 48.42692228428
- Inertia have been defined but incorrectly in the case of Icog=3 and 4.
- Constant inertia has been defined (50) for Jxx, Jyy, Jzz, Jxy, Jxz and Jyz and Isphere is not set to 1.
This warning must be corrected as it could generate problems during the Engine. This can be corrected in HyperCrash.
#700 through #1199
Error 1079
WARNING ID : 1079
** WARNING: CHECK TIED INTERFACE
DESCRIPTION :
-- INTERFACE ID: 1
-- INTERFACE TITLE: new Contact
CONCERNING 1 NODE(S)
SECONDARY NODE: 82 NEAREST SEGMENT : 1 MAIN NODES: 146 145 142 143
S = 1.400000000000 T = 1.160000000000 DIST = 2.9393876913398E-02
82
is outside the main segment, but Radioss treats the projection as moving this secondary
node onto the nearest edge of the segment. S
and
T
are the distance of local 's' and 't' direction.
