Print a small part (also called a coupon) to measure the deformation of the material after printing, and use this
data to calibrate the print analysis.
Support
Create and partition supports required for 3D printing.
Slice
Examine the part in layers to validate its geometry before 3D printing.
Export
Export a file containing the prepared part and/or supports for 3D printing.
Calibration
Print a small part (also called a coupon) to measure the deformation of the material after printing, and use this data to calibrate the print analysis.
Analyze (SLM)
Run a additive manufacturing analysis, then view and plot the results.
