Clean Up CAD on Import
Run a diagnostic test on the imported model to review and fix issues with parts.
For other file formats, you can clean up CAD on import by following the steps below.
Turn on the ability to run diagnostics in the Preferences:
- On the File menu, click the Preferences button to open the Preferences window.
- Under Category, select Inspire > Geometry.
- Under Preference, scroll down to Import from CAD File.
- For Fast import, select With diagnostics.
- To open the CAD file, press Ctrl+O.
- In the History Browser, right-click the CAD model, and then select Run Import Diagnostics.
- In the Diagnostics table, the Name of the parts and the corresponding Issues are listed. For details, see CAD Geometry Issues
- By default, all of the available import options—except Alternate Convert—are used to fix the model. To customize the import options, click the Advanced button, right-click a column header, and then turn on/off the desired import options. For details, see CAD Import Options.
- Select the desired part, and then click the Fix button.
CAD Geometry Issues
Descriptions of CAD geometry issues that may appear in the Diagnostics table.
| Error | Description |
| Not converted | The part couldn't be converted to Parasolid. The Inspire part is therefore empty. |
| Missing faces | Some faces couldn't be converted and are missing in the resulting part. |
| Not solid | After being converted to Parasolid, the part is no longer a solid. |
| Split | The resulting Parasolid part is split because knitting failed partially or completely. |
| Invalid | The Parasolid check detected errors in the resulting part. While the geometry may not be a valid Parasolid part, you could still work with it. |
| Corrupt | The Parasolid check detected that the part is corrupt. The resulting Inspire part remains but is empty. |
| Not tessellated | Since the part couldn't be tessellated at all, the part is empty. |
| Partially tessellated | Tessellation failed for some faces, which will be deleted. |
CAD Import Options
Descriptions of the CAD import options (pre-processing, conversion, post-processing).
| Option | Type | Description |
| Healing (also known as Pre-healing) | Pre-processing | Heal the selected part. |
| Alternate Convert | Conversion | If regular conversion (trimming and knitting) doesn't give the expected results, you can turn on this option to save the selected part into a temporary .x_b file that will be reloaded by Parasolid. |
| Sew | Conversion | When knitting fails, the part is converted into an assembly, holding all pieces. Turn on this option to combine the pieces. |
| Solidify | Post-processing | When there are issues such as gashes, small missing faces, sliver
faces (faces that were deleted because they were non-tessellated),
you can turn on this option to help make parts solid. When tessellation partially fails, non-tessellated faces are deleted and the Solidify operation is performed again. |
| Reset Edge Precision | Post-processing | Recalculate the tolerant edge geometry to improve
precision. While turning this option may not topologically or visually modify the part, it may fix some failing modeling operations. |
