Show, Hide, and Isolate
Show, hide, and isolate objects in the modeling window using keyboard shortcuts.
| To | Do this | Note |
| Show/hide selected objects | Press H. | You can also show or hide objects by:
| Isolate selected objects | Press I. | Isolating an object zooms in and temporarily hides all other objects. |
| Show all/hide all objects | Press A. | |
| Reverse the selection | Press R. | |
| Turn selected parts transparent | Press Ctrl. |
Show/Hide Mode
Use the Show/Hide tool located in the view controls to change the visibility of objects.
or hidden
