Altair® Panopticon
General
All of the visualizations have these general settings:
Property
Title
Title of the visualization.
Double click mode
Sets the behavior to be performed when double-clicking on a visualization value.
Header Controls
Tap the slider to display the header controls such as Export Excel, Toggle Display Mode, Maximize, Rubber Band Zoom, and Rubber Band Selection options.
Shelves
Tap the slider to display the Shelf Variable and Breakdown.
Visible Shelves
Check the boxes of the shelves that will be displayed in the visualization.
Zoom
Enable to reset the zoom on data reload.
Automatic Parameterization
Select the automatic parameterization status: On, Off, or Inherit (default).
Datatable
Allows you to switch to another data table in the workbook to be used in the visualization.
Recalculate Automatic Range on Breakdown Change
Tap the slider for variables with automatic range/mapping to be recalculated when the visible depth is changed in the visualization.
Font
Set the font size, weight, and italicization to be used in the visualization.
NOTE: The available custom fonts on Panopticon Real Time can be selected on the Font drop-down list.
Help Text
The added Help text can be displayed for the visualization.
