Proxy
A proxy is a server or software running on a server that acts as an intermediary for requests from clients seeking resources from other servers. Instead of using a proxy, you can use a load balancer.
It is recommended to use a proxy when setting up Panopticon Real Time. There are a variety of proxies available. One of the most commonly used proxies is Apache HTTP Server with the proxy module. Refer to the section below on how to setup an Apache HTTP Server with Proxy functionality.
Apache HTTP Server
This section describes the steps on how to install and configure an Apache Proxy. The guide expects that the Apache HTTP Server is being setup for the first time. Please note that the installation steps might vary depending on your environment. These steps cover how to install and configure an Apache HTTP Server with proxy support for Microsoft Windows.
1. Download the Apache HTTP Server from the official webpage: https://httpd.apache.org/download.cgi
2. Unzip and copy the files to a folder.
3. Configure the proxy by opening the httpd.conf file in the conf folder.
4. Update the SRVROOT variable. The value must be updated to the file location of the Apache HTTP server.
Define SRVROOT "/Path/To/Apache"
ServerRoot "${SRVROOT}"
5. Modules are required to be loaded to make the Apache HTTP Server into a proxy. Add the following lines in the httpd.conf file.
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_http_module modules/mod_proxy_http.so
LoadModule proxy_wstunnel_module modules/mod_proxy_wstunnel.so
LoadModule rewrite_module modules/mod_rewrite.so
NOTE |
In the httpd.conf file: · Ensure that the line Include conf/extra/httpd-vhosts.conf is uncommented. · Replace Listen 80 with Listen 10080. |
6. Configure the logic for the proxy and how requests should be passed. The Virtual host config should look like this and be added to the httpd-vhosts.conf file in the conf/extra folder:
<VirtualHost *:10080>
ServerAdmin webmaster@localhost
ProxyPreserveHost On
ProxyPass /panopticon http://localhost:8080/panopticon
ProxyPassReverse /panopticon http://localhost:8080/panopticon
ProxyPass /panopticon/server/ws http://localhost:8080/panopticon/server/ws
ServerName localhost:8080
RewriteEngine on
RewriteCond %{HTTP:UPGRADE} ^websocket$ [NC]
RewriteCond %{HTTP:CONNECTION} Upgrade [NC]
RewriteRule .* ws://localhost:8080%{REQUEST_URI} [P]
</VirtualHost>
7. The Apache HTTP Server can be started when all the configurations are in place. This is done by running the httpd script or application in the Apache binfolder.
