Editing an Application
NOTE |
Applications that are started or running cannot be edited.
1. On the Applications tab, click an application link to modify.
The Application page displays.
2. To change the Application Name, click on it to make it editable, then enter a new one and click .
NOTE |
The Name or ID must start with a letter (a to Z) or underscore. Also, it can only contain letters (a to Z), numbers (0 to 9), and underscores.
3. You can also modify or add the following:
4. Save the changes.
To go back to the Applicationstab, click beside the application name.
NOTE |
If there are changes that were not saved, a confirmation message displays asking if you will exit the Application page without saving. Click Cancel and then save.
