Designate one or more parts in your model geometry as guiders to direct the injection
of foaming materials into a foam part.
You must designate a foam part before designating
guiders.
Click the Tooling icon.
In the Tooling sub-ribbon, click the Guider icon.
In the guidebar, click the Guider button. Select a part
in the model to designate it as a guider.
Use the Microdialog to define the Thickness, Conductivity, and Slip Factor of
the Guider.
Thickness defines the average thickness of the guider
part's outer wall. In most cases, the default value of 2 mm will be
correct.
Conductivity defines the thermal
conductivity of the guider part. In most cases, the default value will be
correct.
Slip Factor defines how easily the
material flows through the guider. In most cases, the default value of 0
will be correct, however if the guider has many curved surfaces, 0.2 mm may
yield better results. Values less than -1 or greater
than 1 are not valid.
In the guidebar, click the Outlet button. Select a
surface on the guider component to create an outlet.
In the guidebar, click the Nozzle button. Select a
surface on the guider to create a nozzle.
Use the microdialog to define the nozzle's Material, Material Temperature,
Nozzle Radius, Mass Rate, Start Time, and Holding Time.
Note: The Path checkbox will be
disabled, since guiders are stationary.
Repeat steps 3 through 7 for each guider part in the model.
Right-click and mouse through the check mark to exit, or double-right-click.
