Adhesives
Structural adhesives are simulated as thin layers of adhesive material associated with a connection.
In SimSolid, adhesives can be modeled using two separate methods. Both methods assume that there is a finite gap between the parts to be connected. This gap will be used to calculate the adhesive thickness. When the gap is too small, parts faces coincide or overlap the user will be warned and a minimum thickness will be used.
