Create Laser Weld
Connect contacting surfaces over a strip created on a line or polyline.
- In the Project Tree, click on the Assembly branch.
In the Connections workbench toolbar, click
(Create spot or laser welds).
- Under Type, select the Laser weld radio button.
- In the modeling window, pick points to define a weld line.
- Define the Weld width.
- Click OK to create.
