Create Spot Welds
Connect two parts over a circular area on the contacting surfaces.
You can create stand alone spot welds, create a series of spot welds on a line or polyline, or create spots from a CSV file.
Imported Spot Weld CSV File Format
You can create a .csv file using a spreadsheet program such as Microsoft Excel or Google Sheets. The file must have a header row and one or more additional data rows (one for each spot weld). The header row can have any number of fields but only the following are read.
CSV file format fields
- “X_Pos”, “Y_Pos”, “Z_Pos” – this is the X, Y and Z coordinates of the spot weld location
- “Connected Part 3” (optional) By default SimSolid creates a spot weld between the two closest parts to the XYZ value. If a third part is also desired, place any alpha-numeric value here. This tells SimSolid to create 2 welds between the 3 closest parts.
