Find connections between edges on a single part and any other parts within the
tolerance range.
In the Connections workbench toolbar, click
(Add/Edit part connections).
Click the Edge to surface tab.
Select one or more edges on a single part in the modeling window.
Specify gap and penetration tolerances.
Tip: Set the tolerances just large
enough to cover the intended gap or overlap. Do not set values too large as
this will over-stiffen the model.
Choose the connection Resolution level.
Tip: Try to use the Normal resolution level
whenever possible. Only use Increased or
High resolution levels when the contact area is
small in relation to the overall size of the connecting parts.
Click Find connections.
Connections will be found between the selected edges and any other parts
within the tolerance range.
Tip: This is a good option for sharp
cornered “knife edge” types of geometries.
- Optional:
Use the Delete button to remove unwanted connections
from the Connections found list.
Click OK.
