Base Excitation
Transient Response
Two types of base excitations are possible. The excitation can be specified in terms of displacements or accelerations. Both are applied in the global X, Y or Z coordinate frames only.
You can select the excitation type (displacement or acceleration), time function, scaling amplitude and direction.
In addition, displacement-based excitations can be applied to individual supports which can be important for long ground-based structures like pipe systems, bridges, and transportation systems.
Frequency/Random Response
The excitation can be specified in terms of accelerations. They are applied in the global X, Y or Z coordinate frames only.
You can select the excitation type (acceleration), frequency/psd function, scaling amplitude and direction.
Note: Only immovable and general constraints can be used as the source location. Hinges, springs and sliders are not supported at this time.
