Apply uniform loads and/or displacements to faces, edges, vertices, or
spots.
For dynamic analyses, each load must
reference a time/frequency function curve.Note that Displacement is disabled for Multi-loadcases.
In the Project Tree, open
the Analysis Workbench.
In the workbench toolbar, click the
(Force/Displacement) icon.
Specify which type of entity will have constraints
applied.
- Optional:
If applying to Faces, you can select the Add tangent
faces check box.
- Optional:
If applying to Spots, you can create new spots by clicking Create
new spot.
In the modeling window, click to select specific parts on the model.
Specify the coordinate system to which the force/displacement will be
applied.
The default is set to the Global coordinate system, which is automatically
created upon geometry import.
Specify Cartesian or
Cylindrical.
Specify the Force and Displacement units.
Specify Total load or displacement along the X, Y, and Z axes.
Use the drop-down menu beside each field to select
Force or
Displacement.
Enter the desired numerical value into the text box.
In Non-linear Structural Analysis, specify either follower force or fixed
direction force for each axis.
Click the
(Follower load) icon.
The icon will highlight. This designates a follower
force.
Leave the icon unhighlighted to designate fixed direction force.
Click OK.
