Modify Results Plot
Adjust the display attributes for the results plot.
- In the Project Tree, open the Analysis Workbench.
- On the Analysis workbench toolbar, click the (Results plot) icon.
In the drop-down menu, click the desired plot.
The Legend dialog will open and the chosen contour plot will appear in the modeling window.
Control the contour bounds.
Use the Max and Min text
boxes to set upper and lower contour bounds.
- Use the icon to lock Max and Min contour bounds.
- Use the icon to show the Max and Min labels in the modeling window.
- Under Image, set the contour colors.
- Use the icon to show deformed shapes in the modeling window.
Change deformation scale factor.
- Click the (Change max deformation) icon.
- In the dialog, adjust the slider to the desired setting.
- Optional: Select the Show true deformation check box to set deformation to true scale.
View/adjust the Animation.
Click the icon to play the animation.
The slider will show the current frame of the animation:
- Click the icon to stop the animation.
Use the Animation Speed and Animation
Step sliders to adjust the speed and frames displayed in
the animation.
Note: These sliders will only be active when the animation is playing.
