View dynamic reaction forces.
Project Tree, select a Dynamic analysis branch to open
the Analysis Workbench.
On the workbench toolbar, select the
(Reaction/contact force) icon.
In the dialog, select either the Supports tab or the
Connections tab.
Select supports/connections from the list in the dialog.
Select a Reactions type from the drop-down menu.
- Optional:
If plotting multiple forces, you can select the Show each plot in
separate window check box to create multiple plots.
Click Evaluate.
A new dialog will open showing a graph of the chosen force. You can use
the radio buttons in this dialog to change Y-axis scale.
