Dynamics Analysis
You can evaluate your design in real-time using SimSolid dynamics analysis.
Setup
  1. Specify the modal results to which the analysis is linked. The modal solution must exist in the current design study. In SimSolid, the time integration of the equations of motion is extremely fast and all modes are always included in the analysis.
  2. For Frequency and Random Response, specify the frequency span upper and lower limits. For Transient response, specify Time span.
  3. Specify damping using Rayleigh damping coefficients or Modal damping.
  4. Select the Evaluate peak responses during solving check box to evaluate peak responses during solving phase.
See Create Analysis for additional information.
Damping
Two methods to specify damping are supported.
Rayleigh Damping Coefficient
Assumes the damping matrix is proportional to the mass and stiffness matrices. You need to specify values for Mass (F1) and Stiffness (F2) in the Dynamics creation dialog to use this method.
Modal Damping
Creates critical damping ratio for each mode. You can specify this value in the Dynamics analysis creation dialog.
Notes for Dynamics Analysis
  1. When the base excitation type is displacement, the initial condition for displacement and velocity is always assumed to be zero.
  2. In SimSolid, the boundary compatibility is approximately met. The response at the constrained end is not going to be an absolute zero but is relatively small compared to the peak responses.
  3. Equivalent radiated power density is calculated as:
    ERP   Density   =   ERPRLF   *   (0 .5   *   ERPC   *   ERPRHO)   *   v 2 MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeyraiaabk facaqGqbGaaGjbVlaabseacaqGLbGaaeOBaiaabohacaqGPbGaaeiD aiaabMhacaaMc8UaaeypaiaaykW7caqGfbGaaeOuaiaabcfacaqGsb GaaeitaiaabAeacaaMc8UaaeOkaiaaykW7caqGOaGaaeimaiaab6ca caqG1aGaaGPaVlaabQcacaaMc8UaaeyraiaabkfacaqGqbGaae4qai aaykW7caqGQaGaaGPaVlaabweacaqGsbGaaeiuaiaabkfacaqGibGa ae4taiaabMcacaaMc8UaaiOkaiaaykW7caWG2bWaaWbaaSqabeaaca aIYaaaaaaa@6594@
    Where:
    v MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamODaaaa@36EE@
    Normal velocity of the picked point
    ERPC (Speed of sound in air)
    343 m/s
    ERPRHO (Density of air)
    1.225 Kg/m3
    ERPRLF (Radiation loss factor)
    1
    Equivalent radiated power is calculated as an integral of ERP density over picked faces as:
    ERP   =   ERPRLF   *   (0 .5   *   ERPC   *   ERPRHO)   ∫ S   v 2   d s MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaeyraiaabk facaqGqbGaaGPaVlaab2dacaaMc8UaaeyraiaabkfacaqGqbGaaeOu aiaabYeacaqGgbGaaGPaVlaabQcacaaMc8UaaeikaiaabcdacaqGUa GaaeynaiaaykW7caqGQaGaaGPaVlaabweacaqGsbGaaeiuaiaaboea caaMc8UaaeOkaiaaykW7caqGfbGaaeOuaiaabcfacaqGsbGaaeisai aab+eacaqGPaGaaGPaVlabgUIiYpaaBaaaleaacaWGtbaabeaakiaa yIW7caWG2bWaaWbaaSqabeaacaaIYaaaaOGaaGjcVlaadsgacaWGZb aaaa@633F@
  4. Phase for Absolute displacement can be queried using Pick Info for frequency dynamics.
