Location of Application Definitions
Locate the application definition in central server and in your local system.
Application definitions can be stored either on the local desktop or in a central repository.
Access Desktop UI will be updated with any changes in local application definition after removing the time stamp (time_stamp.txt). Notification will also be displayed about the application definition update.
When they are stored in a central repository, then the application definitions are stored on the server host Access Web in the location:
/var/spool/pbsworks/2022.1.0/access/home/data/pas/targets/<PBS_SERVER_HOSTNAME>/repository/applications/
When they are being stored locally, the application definitions are stored at:
%USERPROFILE%\Altair_Access\home\apps\PAS\data\pas\targets\<cluster name>\repository\applications\
  1. Open the Windows system tray.
  2. Double-click the Access Desktop icon .
  3. Click .
  4. Select Show Applications.
    The folder containing the cluster or PBS Server registered is opened in Windows Explorer.
  5. Select the <PBS_SERVER_HOSTNAME> or <localhost> directory.
  6. Navigate to the repository directory.
  7. Navigate to the applicatons directory.
    The list of application definition will be displayed.
