Rearrange Listing Columns
Columns can be rearranged in the list view.
To rearrange the order of the list attributes in the list view, drag a column heading horizontally either right or left. Any of the attributes can be moved horizontally right or left within the group of attributes.
The list view columns can be rearranged in Files, Jobs, Desktops, Input, Output, Running Folder tab.
In this example, we will change the rearrange column in the Job Monitoring list view.
  1. Click the Jobs tab located in the upper left-hand of the page.
    The job monitoring page is displayed with the list of the jobs that is submitted to a cluster.
  2. Select the Status column and drag the column to the left.
    Figure: Rearrange Column
    The job attribute Status will be moved to the location that was selected.
