Grant PBS Manager and Operator privileges, specify whether users can query the status of jobs owned by another user, and specify
how usernames are treated across all machines in a HPC cluster.
The real-time dashboard in Control (currently in preview release stage), provides live data in a single page to view
several aspects about the overall operation of a cluster.
Make changes to settings to modify the behavior of the Workload Manager
Scheduler.
Implement Backfilling
Implement backfilling to keep resources from becoming idle when the top job cannot run.
Implement Starving Jobs
Track the amount of time a job has been waiting to run and then mark the job as starving if this time has passed a specified limit.
Implement Placement Sets
Use placement sets to improve task placement by exposing information on system configuration and topology.
Implement Fairshare
Implement fairshare to ensure that jobs are run in the order of how deserving they are.
Configure Fuzzy Backfilling
Trade-off between scheduling cycle speed and the fineness of the granularity with which estimated start times are calculated.
