Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
  1. Use the model considered in Dipole in Front of a Plate with MoM and rename the file.
  2. Set the solver method for the rectangular plate to use UTD.
    Tip: Open the Modify Face dialog and click the Solution tab. From the Solve with special solution method list, select Uniform theory of diffraction (UTD).
