Pin-Fed, FDTD Model
Model a microstrip patch antenna using a feed pin and a finite substrate. The patch antenna is solved with the finite difference time domain (FDTD).
![](../../../../images/feko/example_guide/EG_A08_patch_microstrip_rect/intro_pin_fdtd.png)
Figure 1. A 3D view of the pin-fed microstrip patch antenna on a finite ground.
